There is an advantage in using higher compliance drivers in car apart from the advantage of keeping the enclosure size smaller.
The problem with subwoofers in car is their location, which primarily has to be in the boot, not the most ideal as the midbass drivers are usually mounted at the base of the front doors and the integration becomes difficult unless you have an active DSP with lots of features to adjust crossover, gain, phase etc.
Even in the most airtight door install of midbass (I have seen installs where fabrication has been done to create a dedicated sealed enclosure in doors), it is almost impossible to achieve an inert condition. The doors themselves will resonate and add their own character, how much ever you damp them. I have myself done special fiberglass fabrication with multiple spacers to increase the door depth for midbass in my car by utilizing the cabin space. My doors are very well damped with aluminium backed tarfelt sheets with woolen pads behind the driver to absorbe rear waves.
Here is the pic of the midbass in my car.
Here without the grill
To lower the impact of the high frequency noise perpetrating into the car cabin, some absorbent, diffusion materials and I have also read some cancellation techniques are used to keep the noise to frequencies under 250hz...so usually in cars, with all windows up we usually only hear a kind of rumble. This rumble too adds to the lower midbass and sub frequencies.
So ideally most car midbass drivers will perform poorly if the HPF is under 100hz, and 80hz in well damped doors. Anything below 80 will start to bottom out and bring down the life of the midbass.
So a subwoofer with a lower f/s and a higher Q works favorably in cars as the subs cam be conveniently crossed at 80 with a deeper slope.
Such subwoofers are usually of higher compliance in nature with not that stiff a suspension, so installing then in lower sized box will give a good enclosure air spring to the driver cone.
If you want a bigger enclosure without increasing the size, just add some glasswool, it could though push the F3 a few notch.
if you see commonly, the car subwoofers also have huge magnets.
