Water softner for Bathroom
srikar2011
Hyderabad
Hi Friends,
I stay in rented house in Bangalore where we get hard water. Looking for a water softener at a reasonable price. Kindly suggest
Srikar
This should help. I had earlier installed similar product like this. Depending upon the water hardness the filter needs to be changed after 6 months to 1 year. The water will pass through this filter and will come out slowly through the outlet. The reddish water would be crystal clear
Whole Tap Iron Remover and Anti-scaling Filter: Amazon.in: Home & Kitchen
Thanks, Hope the above product can be fixed to a tap in bathroom for bathing purpose. Since there will be 2 taps, one for hot water and other for normal water, do I need one more unit? Does the above product also suffice for washing machine too?
I am planning to purchase below product for washing machine
Eco Crystal Aqua Merit Water Softener for washing machine: Amazon.in: Home & Kitchen
Srikar
Yes, it can be fixed. You can use this for washing machine also and buy another separate unit. The one you have mentioned is also good but if you buy a bigger one with large filter the water flow would be fast especially for a washing machine.
