HiFiVision
Super Moderator
Pioneer SX-10AE Stereo Receiver plus Wharfedale Diamond 11.2 Speakers
This stereo package consist of:One Piece Pioneer SX-10AE Stereo Receiver (Black Finish)
Listen to powerful, lively sound and dynamic bass with Pioneer’s SX-10AE stereo receiver. In addition to AM/FM radio entertainment, you can hook up a CD player and play albums, or a network audio player and enjoy music streaming services. Bluetooth® Wireless Technology lets you easily stream songs from smartphones and tablets.Amplification & Design
› Application Type: Direct Energy
› Analogue Discrete 2ch Amplifier
› 100 W/ch (6 ohms, 1 kHz, THD 1.0 %, 1ch Driven)
› Screw Type Speaker Terminals Compatible with Thick Cables
Audio Features
› Direct Mode for Pure Sound Output as Originally Intended
› THD: 0.08 %
› S/N Ratio: LINE In, SP Out 100 dB
› Tone Controls: Bass (100 Hz)/Treble (10 kHz): ±10 dB
› Frequency Response: DIRECT 10 Hz-100 kHz, +1 dB/-3 dB
Convenience Features
› Bluetooth® Wireless Technology (Ver. 4.2, Profile: A2DP/AVRCP, Codec: SBC/AAC)
› AM/FM (RDS) Tuner with 40 Station Presets
› Preset Station Naming (Up to 10 Characters)
› Speaker A/B Selector
› FL Display
› Sleep Timer
› Auto Standby
Terminals
› Phones 1 out
› 4 Analogue Audio in (CD, NETWORK, LINE 1, LINE 2)
› Line 1 out
› Subwoofer Preout
SPECIFICATIONS
› Power Requirements: AC 220-240 V, 50/60 Hz
› Power Consumption (in Use/in Standby): 160 W/0.4 W
› Dimensions (W x H x D): 435 x 147 x 321 mm
› Weight (Without Package): 7.0 kg
Direct Energy Design
Every inch of the chassis has been devised to create quality sound, such as shorter transmission path, clean grounding, and rigid structure with improved damping. The discrete amplifier inherits the Direct Energy Design of Pioneer’s high-end AV receivers for faithful reproduction of the audio content.Bluetooth® Wireless Technology
With the built-in Bluetooth® Wireless Technology (ver. 4.2), you can easily stream songs from compatible devices such as smartphones and tablets. The SX-10AE features A2DP and AVRCP profiles, with support for SBC and AAC codecs.AM/FM (RDS) Tuner with Presets
The automatic tuning feature lets you easily find stations in your area. Manual tuning is also available. You can save up to 40 stations on the receiver’s preset for quick access. Radio Data System (RDS) is a system used by FM radio stations that provide users with various kinds of information such as station name or the programme type. You can search program types such as news, sports, weather, rock, classics, and jazz using the remote control.Auto Standby
The SX-10AE will automatically turn off after being left uncontrolled for a certain time set by the user.One Pair Wharfedale Diamond 11.2 Bookshelf Speakers (Walnut Finish)
The Wharfedale Diamond 11.2 Bookshelf Speaker is a classic entry point to true high-fidelity sound, their exceptional value for money earning numerous ‘product of the year’ awards in the UK and around the world. Now, with the introduction of the all-new Diamond 11 Series, Wharfedale has once again raised the bar for affordable, high-performance loudspeakers.The latest generation of Diamond speakers includes design elements never previously seen at such affordable price points. At the start of the design process, Wharfedale’s engineers went back to basics to create a loudspeaker system that would once again revolutionise this sector of the hi-fi market and bring high-end performance – and style – within reach of many music lovers, not just the wealthy few.
Advanced driver systems of the Wharfedale Diamond 11.2 Bookshelf Speakers (PAIR)
Diamond 11 features massive magnet designs to both raise sensitivity and ensure absolute control of cone movement over lower bass frequencies. In addition, the use of a specially shaped top plate with a copper cap controls the magnetic flux and ensures low distortion through the critical midrange area.Then there is the suspension which features a lightweight progressive rubber surround, in conjunction with a super-long-throw voice coil motor system, to achieve unparalleled linearity and accuracy in this sector of the market.
Cabinet construction of the Wharfedale Diamond 11.2 Bookshelf Speakers (PAIR)
While the cabinet, to the owner, is often just a piece of furniture, at Wharfedale we have long realised that it is the final piece of the design process that marks a loudspeaker out of the ordinary.For Diamond 11 our engineers have refined the multi-layer sandwich of differing woods to subdue the identifiable characteristics of the cabinet ‘sound’ and so let the drive units speak for themselves.
Critical bracing of the cabinet panels and, of course, the curving of the cabinet walls to provide a non-boxy shape, have reduced resonances more than 25dB below the driver outputs. In addition we use a specially developed internal fibre to line the cabinet walls which has been chosen because of its outstanding absorbent qualities across a wide bandwidth.
Slot-loaded distributed port available on the Wharfedale Diamond 11.2 Bookshelf Speakers (PAIR)
The slot-loaded distributed port is a recent Diamond innovation where the internal port tube opens into a slot formed between the cabinet and the plinth. This not only reduces the turbulence caused by the sudden outrush of high-pressure air into the low pressure in the room, suffered by conventional ported systems, but also increases the efficiency of transfer of energy from the bass reflex tuning to the room.For Diamond 11 we have taken this one stage further, profiling both ends of the port with a semi-parabolic exit curve that linearises airflow through the port tube. This has allowed us to increase the volume of air in the slot-loaded system and further improve the performance of the low-frequency output.
The result is an entirely natural and low distortion recreation of the fundamental notes of bass instruments, matching the realistic sound of the midrange and treble characteristics. The low Q nature of this ported system also allows the listener to position Diamond 11 speakers close to a rear wall, helping to make the speakers less obtrusive in a room setting.
Specifications of the Wharfedale Diamond 11.2 Bookshelf Speakers
- Configuration 2-way bookshelf
- Enclosure type Bass reflex (slot- loaded)
- Bass/mid driver 150mm woven Kevlar
- Tweeter 25mm textile dome
- Sensitivity 88dB
- Recommended amp power 25-125W
- Nominal impedance 8 Ohms compatible
- Frequency response 48Hz-20kHz
- Cabinet volume 13.2L
- Dimensions (HxWxD) 355x221x290mm
- Finish: Walnut Pearl
