sudhirbhosale
Hi all
In HiFi, there is lot of price variations between Entry level and High end models, mainly in Amplifiers, speakers and sources. So curious to know what extra one can get after spending 10x or 100x price. Some time 10x additional spend may boost SQ by 3x only, not proportional to cost. So I tried to contact helpdesk of some companies but did not get clear answers except below:
1. Cambridge audio replied that in costly models, high grade components are used. Then I asked since specs like TDH, etc are same, so what would be difference to the end listeners? No further reply on that
2. One DAC company clearly mentioned that due to high grade components, though specs are same, there would be difference in sonical experience.
Till date I found below answers. I mentioned below my findings wrt High cost vs benefits. Request FM to add in case there are more benefits by spending more.
1. High grade components = long life, reliability, lower variation in results, less noise
2. Solid Build quality i.e. less plastic, more metal, gold, sliver, brass, high grade switches, transformers, heavy stuff = improved trouble free life
3. More features & more connections options, like pre-out, MM+MC support for phono, two pair speakers output, variable loudness control, digital+optical in for audio
4. Where there are few technical options while designing etc. power supply transformer, always selected high quality design options. e.g. toroidal vs normal transformer
5. Some propitiatory stuff where company invested in huge R&D and now patented hence more cost
6 Separation / dedicated approach which may require 2x set of component. i.e. Cambridge audio higher DAC have two DAC chips separate to Left and right channel.
7. Purity approach i.e. pure gold, pure copper connectors, many pure stuff
Any more benefit for spending more?
Do always result into too high grade SQ same time?
