max123_ind
The DVD format uses a form of anamorphic enhancement to maximize the resolution of standard-def content for display on a 16:9 screen.
All NTSC DVDs are encoded at a resolution of 720x480 pixels, whether the content is 4:3 in aspect ratio or wider. (PAL resolution is 720x540.) You'll note that 720 divided by 480 yields a mathematical sum of 1.5, which is neither the same as 4:3 (1.33:1) or 16:9 (1.78:1). That's because DVD uses non-square pixels. An anamorphically enhanced DVD is mastered in a "squeezed" format that will return to correct geometric proportion when "unsqueezed" (or horizontally stretched) by the 16:9 TV.
On the other hand, there is NO anamorphic enhancement on Blu-ray. Blu-ray video is natively 16:9 in aspect ratio, with a resolution of 1920x1080 square pixels. Any movie content wider than 1.78:1 must be letterboxed within the 16:9 pixel grid. Anything narrower must be pillarboxed on the sides. The format has no squeezing or stretching.
P.S. : The source is from HighDefDigest site which also speaks about philips 21:9 TV but I picked only what is necessary about DVDs. Also this may be old info but just thought I'd post anyways.
