Which Glue / Adhesive to use to stick Speaker Fabric
kisbak
Hyderabad
I have some antique Sony speakers (ss-S440) for which i would like to change the fabric. What is the best adhesive to use for sticking the fabric?
I used the regular Fevibond - use clips [I used cloth clips] to help stretch and keep the cloth in place with the glue. After an hour or so you're set!
