XDA-1 DAC vs Xonar Essensce ST : which is better ?
Spidey
India
hi guys,
I am planning to setup a HTPC rig with first aim in stereo playback.
I need very good sound (?analogue).
So, should it be :
PC > XONAR essence ST > RCAs > Preamp
PC > Optical > XDA1-DAC > Preamp
pls give your valuable suggestions.
thanks
Re: XDA-D1 DAC vs Xonar Essensce ST : which is better ?
^ we know works great. We have several members who can vouch for it.
^ we'll know once the Emotiva XDA DAC is released/reviewed. What we do know is this will be easier to use, offer many more connections and types of connections including USB. I see you have mentioned Optical, which IMO is not necessary as the USB should suffice. You can save some $ on a good soundcard/good MOBO as you don't need a HTPC...any PC/Laptop with USB 2.0 will do just well.
DAC can do better job than SC & will have more options.Only time will tell once DAC is out.
From emotiva site : "In addition to being a state of the art 24Bit/192kHz DAC, the XDA-1 can operate as a digital preamplifier ".
What is digital preamp? Is it just a regular preamp? I am confused
Satya
umm
spidey
why do you need to have the preamp in the chain?
the Xonar essence by itself is a nice preamp and the XDA has a pre amp too
By adding a preamp you wont achiev much in your current setup
Yes if youre looking at multiple inputs when using the Xonar well thats a different story
But other than that
Unless your are going vinyl or have some specific flavour in mind i dont really see the need for a preamp if its just for 2 channel audio in your setup.
Add to that UNFORTUNATELY it does not have analouge inputs ..otherwise it would be a nice preamplifier!
analogue inputs could have been added easily
but obviously no company having a regulr 300$ preamp would provide that!
hmm you can also put to your list the dac from Viren, Lyrita. I think he can put pre too in the same box. Not very sure about the pricing but I think it would be costlier.
Spidey what is your HTPC's config? Any soundcard in it?
Why not adding SC in HTPC and controlling it by ipad?
I have no specific htpc but my pc is core2 duo.
That's what I was thinking to invest in a sound card or ext DAC.
Xonar st 9k vs xda dac ~ 20k.
