My first DIY project is complete. This was the mandatory speaker stand.
I started with the famous 2 wood planks and a pvc pipe design. However did not like the look of PVC pipe and dreaded the thought of sand leaking through the pipe. So thought of using scrap plywood to build the leg. Gave some job to my newly bought drill. Cut a large number of circular wooden pieces and glued them together. Plywood with veneer used for both top and bottom portions.
This was specifically build for my Monitor audio BR2 speakers.
[/ATTACH]
[/ATTACH]
