HTS 12 vs Wharfedale D10, or any other suggestions?
navkchennai
Chennai
Current setup :
Speakers - Mission QX2 MK2
Amp - Fosi audio V3
Source - Spotify and FLAC audio through PC RCA
Looking for adding a Subwoofer to the setup. Came across Wharfedale D10 and Polk Audio HTS 12 at 51k INR (approx 615 USD). Any other suggestions that are available in India. SVS, RSL, Monoprice are either not available in India or priced above 1200 USD. Not planning to spend more than 50k/600 USD.
Primary usage is stereo listening and in future expand to a 5.1 setup with a dedicated media room.
Another complication with using Fosi audio V3, is that the pre amp out is not variable and hence volume needs to be adjusted at the source, any workarounds suggested on this?
Current setup :
Amp - Fosi audio V3
Polk HTS 12 has speaker level input and output,
This is give easy integration between speaker and sub ,
Less than 50k it is good sub ,
If you are planning any other subwoofer please check speaker level input and output available.
