10000 mfd Capacitors:
flat_listener
Hyderabad
Hi all,
I am looking for 8 nos. 10000mfd /100vdc snap in type electrolytic capacitors for power supply filtering.
Any on line source where i can procure these?
TIA
Try Samwha/Keltron/Nichicon/Elna caps for power filtering and you can try the following online sites:
The trafo is 60-0-60 vac secondary, which after rectification will be 85VDC.
Even with a very high ripple factor, the dc voltage will be always less than the peak voltage i.e. 85V if I still remember the bridge rectification concept correctly.
