1blu-ray+ 1 av and 1stereo amp
midfree
England
Hi all iv got a Toshiba blu-ray player and it has a digital coaxal out and L+R phono out can I use my nad stereo amp and my jvc 5.1av at the same time for music without damaging any of my equipment. The music comes out in sync and sounds just how I like it any help or advice would be appreciated. Thanks
You need to be more descriptive to attract responses.
It's pretty unusual for a BDP to have a "Phono" out. Most likely they will be "Line out". If you are unsure, try posting a picture of the rear of the BDP. Also, if you post the exact model number some people might search for missing info and try to help you.
If you are hooking the equipments correctly, you will not be damaging any thing. It's perfectly fine to hook the stereo amp to the Line out and AVR to Coaxial out of your BDP. Worst case scenario, your BDP will only output to digital or analog (some players do that). But you will in no way damaging any equipment.
