2.1 Speaker required for TV
cyber_sam
kolkata
Dear Fellow members,
I need a 2.1 speaker set for my TV (optical support will be great :rolleyes:)
basically I will be connecting a PC to my TV and route the audio from PC via HDMI into TV and then via optical or RCA want the sound out.
Budget is 5-10 K.
Please help
many Thanks in advance
Rs 11,500 on hifimart. The link is on the top of the HFV page, just in case you did not know.
If you are open to used AVR's, get hold of a nice one for 7 - 8K..These old AVR's would have Optical/Co-axial inputs.. so you can connect them to your TV output....
Try to search for Micro hi-fi speakers from Onkyo/Denon in Olx & QuickR... YOu should be able to get used ones for 3- 4 K...
So 10 +/- 1K, you have good 2.0 system... Later if you have budget, you can also expand to 5.1 :ohyeah:
