3 Way or Bust!
Rud31
Haryana
1. Suggest selection of a Mid and Tweeter for a 3 way build, has to be cheap
2. Help me build passive crossover for the above.
After almost 2 years, I'm thinking of getting back into DIY. Earlier I assembled couple of Subwoofers and have couple of 8 inchers lying around. Instead of pawning them off, I want to put them in a 3 way config. As I have limited knowledge of Electronics and limited availability of DIY resources at my current location, I want to keep this build also as assemble only. So what I have right now is couple of subwoofers and passive low pass filters for them(150Hz, 12dB).
What I want/need is couple of Mid-range/Woofers and Tweeters and a pair of custom high pass crossovers(will probably have to build them). So please suggest me how should I go about both. Regarding the driver selection, I have seen what DIY Audio Cart/Part has to offer and they aren't my first choice. Earlier saw a post about IWAI drivers so a bit inquisitive to know if they are any good and if they handle small orders?
