3D Readyness of Optoma ML550
ajopaul
I could not find much on Optoma ML550 over here. I was planning to get either Dell M110/M115 from USA, when amazon suggested this model. The 3D ready feature attracted me to this, but I am not what this means.
The spec says the following about 3D.
The ML550 is 3D ready, delivering XGA resolution 120HZ thru the VGA port (the equivalent of 3D-PC). The projector can deliver a 50-inch 3D image with plenty of brightness
Does the PC in this case should be anything different from a regular one, i.e. should it have a high end graphics card that has some 3D capability ? Meaning a regular nvidia based laptop will not be able to render the 3D content?
Also the price was more or less similar to Dell M115hd, was just not sure if it worthwhile to go for it just for the 3D.
I know that i can get Acer 53570 for the same price, but there's no way I can convince anyone to get it for me from US. A palm top led is only one I can get it. Any other suggestion for LED projectors with similar specs and budget.
