42 inch fullhd led tv
nit459
satara,maharashtra,india
I want to buy 42 inch fullhd led tv urgent suggesion pl.
Hi, everybody
I want to purchase 42 inch full HDTV led TVs and my budget is 40 k. Please help me and suggest the models.
Thanks...
at this budget try semi hd 42 inch samsung plasmas at 39k.........
kicks ass of any TV regarding picture quality even within 55k range.....
also if pana semi hd avilable within 37k...
also full hd plasmas are avilable in ~45k.........
if you want to stick led....toshiba has cheaper models..can try that.
Re: I want to buy 42 inch fullhd led tv urgent suggesion pl.
Hi, everybody
Thanks...
you might not get these features in the leading brand-
You might want to check VU/VIDEOCON/CROMA/lloyd if you are not brand conscious.
Thanks for suggestions
Actually I increased my budget and bought 40ex430 Sony led for 53k.
I just wanted to know which video format run (USB) on 40ex430 Sony model.please.replay...
good buy - in sony i suppose very few formats play using the USB .
Wat does the manual say and what did the sales commit ?
wtever - dont worry about the USB- You might use it like once in a blue moon or never use it.Just enjoy the TV-Happy viewing.
ANy particular reason why you didnt consider panny TH50 which costs 10 k less ??
