5.1 Speaker - For Onkyo 705
vickysami
Hi Everyone,
I am new here and I am from Bangalore and by looking around I came to know there are lot of options for 5.1 speakers but in the end buying 5.1 at 20000 rupees is not possible.... isn't it ?
I have a LG scarlet 42" LCD TV and LG DV 388 DVD PLayer (HDMI).
Onkyo 705 will cost around 43000 rupees so investing on speakers would be less.
I was planing for JBL CS680 or Infinity TSS-800CHR but the JBL will cost around 38000 rupees (that's too much) and Infinity price I don't know.
I don't like to go for towers as space is matter here. Satellites would be my choice.
Later I would upgrade it to 7.1.
Any suggestion on speakers that will cost around 20000 - 25000 (upto 30) rupees (500watt and it should produce clear voice and sound).
Thanks, waiting for positive feedback.
vicky
Why dont you look at the Onkyo spkr packages ?
HTP-L50 Speaker Package
or Wharfedale Diamond 9 HCP ?
rgds
Srinivas
Not sure about the price of the Diamond 9 HCP. Check with your local dealer or Designer-Audio the distributor in Mumbai.
