5.1 speakers with digital optical i/p
rpk
TN
recently bought LG 42 LN5710, it have only digital audio out.
kindly suggest any 5.1 speakers with optical i/p, under 15K:)
As far as I am aware, there is no speaker system under 15k with Optical In.
Best will be Yamaha yht 196 @ 20k if you can up your budget
Logitech Z906 @ 17k
can Edifer C6XD decode both dts & DD
As far as i know, it does not do both. If you are bent on budget then the best option would be logitech z906 with DTS, Dolby Digital and THX. For the price its kind of fine. Or you want on higher range - then those HTIB's would suit you.
If the source is from TV I feel it is not worth spending 15K . You can as well go for a sound bar for around Rs.5K
Alternatively with a reasonable budget go for a Home theater where you can enjoy quality sound from DVD/BDP, STB , Music palyers, Builtin FM Radio and Tv etc.
