7.1 in 5.1 audio.....
manu4panjab
in my house..,
hey bros.
i have only 5.1 set up and my bro send me kick ass blu ray movie which will arrive next week ,it has 7.1 audio i want to know if i play in 5.1 do i get 5.1 hd audio or simple 5.1
Manu, as long as you player or AVR receiver can decode HD Audio, you will get HD audio in 5.1 and/or 7.1.
5.1 HD is format on most of the BDs & you will certainly get lossless sound.
Only few as you said has true 7.1.
so the simple ans. is i can get 5.1 audio in hd right not normal old dolby digital or dts right
Yes, its best to leave sound unprocessed. Send unprocessed audio from source (select bitstream or passthrough) and receiver can either downmix to 5.1 or ignore two channels depending on settings.
Manu, send the Blu-Ray data in raw format and let the Emotiva process the audio signals. You will get full HD lossless Audio. Since you have only 5.1 speaker set, the system will play the lossless audio in the 5.1 set.
sir u mean to say bitstream not linear pcm right
