Above normal height wall mount
amit11
Pune
Hi Friends,
Is mounting bookshelf speaker above normal height (wall mounting) a total no-no for stereo listening? In case due to furniture, floor and space constraints if we do not have space then what can be the option.
Amit.
The problem is the distance from the back wall and tweeter level relative to the ear. Wall mounting is still OK but positioning above normal height means the listening position becomes very narrow.
It can be done for HT but for Audio try to get it ear level.
How high is it above ear level?
If it's not way above, you can try using isolating stands like the Isoacoustic stands which can tilt the monitor to your ear level. It can provide 6.5 degree of tilt in upward or downward direction
