Advice required in centre speaker
czarofindia
chennai
Friends,
I have a marantz SR5400 with Boston a23 fronts which is working well. Having planned to upgrade stage by stage I have added a centre speaker, a pioneer Andrew Jones centre.
I am having a problem after connecting all 3 speakers, front and centre.
The fronts are working fine but no sound front the centre.
The pioneer is working fine as I have tried connecting this to one of the front slots.
Is this a set up problem? Or will 5.1 work only if u connect all 5 speakers??
Please help.
Pl check the speaker configuration, most likely Center speaker is selected to be 'None'. If it is so, set it to small. However, if this is not the case then I am afraid problem would be with the amp Center channel and u may have to take it to service Center.
Few things that you need to check...
1) after adding the center channel speaker, did you access the menu in the On Screen Display and make Center channel " yes" ....
2) To make 5.1 material work on your AVR, you need to set the surrounds & surround back to "NO"
3) Good chances that the movie you tried playing contains only 2 chances of Dolby Digital sound track
What is the source of movies... and how have you connected to the AVR ?
