affordable dac, detailed but not clinical, any recommendations
jenson
Indore
my chain: marantz sacd player -> lyrita dht pre -> lyrita 2a3 - > rethm saadhna V1 (lowther version)
i get a feeling my source is too clinical and doesnt gel with the rest of the setup..., how do i address this. is there any recommendations around source for this setup. im ok to experiment with computer as a source before making a call on the cd player...
what is getting clearer is, i do not like clinical sound. i am itching say i would prefer a muddled sound with harmonics, warm and fleshy mids. does this make any sense :) ?
Which marantz sacd player do you have ?
Marantz house sound is never thought to be clinical
i think IC's are half gotham and half mogami, speaker cables are from murthy...you think this system is sensitive to cables...?
I really doubt it's your cables or the CD player
I am no expert in lowthers or any other type of drivers or speakers. But what I have heard lowthers have a certain shout in the mid range which all designers try to tackle in some way or other
Are you referring to that shoutiness ?
i get that warmth in some cd's and not in most. so i am thinking, the system is not forgiving to most recordings. while i agree that the lowthers have a lively, energetic sound with lots of detail, it's mating with the subwoofer unit softens the overall sound signature to a great extent.
If a DHT pre and 2A3 power cant give you the warmth then it's gotta be the speakers...
OTOH you could roll some tubes and see.
I do not think changing the source will accomplish much.
I have had these speakers. They are not bright. The problem is somewhere else
yes, i believe so too. it is not the speaker. could be cables or the source... or both
any thoughts on how to do the eliminations...
planning to do the same, not related to this speacific thread, but Viren suggested i replace stock 2a3s with the RCA 2a3. he felt it would bring positive changes. i have written to him on cables as well...awaiting response on same...
The line up is great still no warmth ???? Try Objective DAC and play some lossless and see if it’s the source.
I do think it’s the source.
I am having great fun playing lossless and streaming through RPi2 with USB O-DAC and tube line-up to full range drivers.
please provide some detail on this via PM... "RPi2 with USB O-DAC"
could it also be the fact that this is placed in a 12 by 10 room, which leaves me no option but to have a near field listening (4-5 feet away, close to back wall), i understand this speaker requires minimum 20 by 18 at least..
Try putting any kind of thick absorbers behind the speakers.
Direct behind speakers, and in centre part
Check if you hear any difference.
That's the key, if you hear any difference
The khadas is not a bad dac
The rcam r dac is also decent
Trying toeing the speakers away from your ears
Take another speaker cable on loan
Try it out
Then do the procedure with each cable on by one
P.s : your issue is a but peculiar though
I agree with Viren that changing from the Chinese 2A3C tubes to the RCA 2A3 tubes will be a big improvement. While the Chinese tubes are among the better new production 2A3 tubes they do have a glassy sounding top end. Another less expensive way to get the sound you are after is to change the rectifier tube in the 2A3 amp from the Russian 5U4c to a RCA 5V4G or Brimar 5V4G. The Russian rectifier is a very good tube and is a good match when used with warm euphonic tubes like ecc83, 6SL7 etc .
I am not sure if your DHT pre can take the 5V4/GZ34/5Z4 type rectifiers , some of the Lyrita DHT preamps use the 6X4 type rectifier. If it can try experimenting with the different rectifiers.
Rajiv
I have no idea why its sounding bright then. Check if any of the wires from the lowther driver has become loose
Your source is cds? Which songs sound bright? The Rethms are ruthless. If your source recording is not upto the mark, it’s going to show up. It can’t handle compressed recordings.
