Hi guys, i am planning to buy Airtel HD STB, my question is what all out audio outputs the STB is having? co axial or optical? i read some where new HD STBs are having only optical ? what would be cost of optical cable?
It has optical out. Decent cable would cost you 300-400.
Cnt say. I only hv a 2.0 setup.
Strange I have Airtel HD STB with coaxial out.
One basic suggestion before considering optical /coaxial, dont buy Airtel if you have other options such as Tata sky.
Saying this because I have Airtel, and you cant simply have a peaceful life when you have to deal with their CC.
On a separate note, they mostly have optical out, but there is no standarad there either. So buy cables only after you have received the box and seen the output connections yourself. Also, make sure to replace the HDMI cable which comes free with box with a decent one.
