Alternate tower speaker which can be compared with Polk RTi A5 ?
arijitghosh
Kolkata
Guys,
Could you please let me know your views that which are the tower speakers that can be compared with Polk RTi A5 ?
I like Music : Movie = 60 : 40. The tower speakers budget should be within 50K
Would very much like to know what you ll be using to drive the Speakers equivalent of RTi A5s with ? What Amp are you having or planning to buy? because I think that effects the speakers choice too..
Guys,
Couls you please let me know your views that which are the tower speakers that can be compared with Polk RTi A5 ?
You have Harmonie audio dealing in Usher (in kolkata). Why dont you try the V-602 speaker? It has similar specs to the RTi A5 but is much better built in terms of cabinet (almost twice the weight) and it is a relatively easy speaker to drive
cheers
please check with Harmonie on local pricing, it should be (retail) approx low 60's and low 80s respectively.
cheers
cheers
Which one did you buy - Polk audio or usher ? I am unable to decide between the two ? Any feedback on either rti a5 or v 602 would be helpful. I am going for Denon avr 2312.
Rajeevgin
