Amkette Flash Tv HD Play no 5.1 sound from optical connection
santhukp
Chennai
Hi all, recently bought this player and connected to my Philips home theatre using optical out. But I am not getting the true 5.1 sound from that. Any one using this player please advice.
I use this product and have no problem getting 5.1 sound. Could it be the settings on the amplifier? You could try another file. Also a speaker test on the amp can help rule out any issue with the amp setting. Otherwise, it just means that one of the components or cable is not functioning correctly.
Best wishes
