Are you happy with your phono stage?
  • Happy
    Votes: 9 81.8%
  • Unhappy
    Votes: 3 27.3%
  • Neither happy nor unhappy
    Votes: 1 9.1%
  • I know someone else who is happy
    Votes: 1 9.1%
  • I know someone else who is unhappy
    Votes: 1 9.1%
  • I don't know what a phono stage is
    Votes: 1 9.1%
  • Total voters
    11
reignofchaos
Question for all analogphiles here - what do you think of your phono stage? What phono are you using? Have you experimented with any others? How happy are you?
Photos of your phono stages will be nice too.
I don’t have much fancy gear . However I have the luxury of a largish room — exclusive for two channel listening — which allows me to place the speakers as per the following :
Room Dimensions
  • Width: 184.1 inches (15.34 ft)
  • Depth: 219.2 inches (18.27 ft)
  • Height: 95 inches (7.92 ft)
  • Volume: ~2212 cubic feet
Speaker Details
  • Model: Omega Super 8 Alnico
  • Center-to-center spacing: 80 inches (6.67 ft)
  • Distance from front wall: 72 inches (6.0 ft)
  • Distance from side walls: 52.05 inches (4.34 ft)
  • Toe in about 5 degrees
Listener Position
  • Distance from speaker line (perpendicular bisector): 68 inches (5.67 ft)
  • Distance to each speaker: ~79 inches (6.58 ft)
The above remains constant for both analog and digital sources. I just listen to jazz on cds or lp , so no streaming , at least not in this room.
My analog cannot hold a candle to the digital . The advantage of the analog is just the immediacy of the sound and the more tactile bass I get. And the wow factor from friends who visit to listen sometimes. They are not much into the nuances of listening but many revel in the chance to listen to a record player , which they have either only read about somewhere or have experienced somewhat in an unfulfilling way in their childhood .
I think the culprit is the phono. When I briefly replaced my current phono ( musica pho30 , a Japanese boutique phono with a small tube buffer , bought from Mr Sridhar Reddy ) with one made by a forum member , the detail retrieval by the DIY phono was better . Unfortunately that device died and I haven’t got around to getting that checked by mechanic . The turntable though very old spins dead quiet.
My cd player was bought in 2009 and it’s still playing well . I don’t remember ever cleaning the lens . The room is relatively dust free. I don’t know if I should invest in a better cd player ( though this player might still play for another 5 years and who knows if cd players would have got obsolete by then ) or a better phono. I don’t have the output impedance values of the musica phono , but I don’t think it’s low enough for it to have good synergy , with the amp.
Trigon Advance.
Definitely happy.
Was happy with Sachu's CNC also earlier but was only battery when I got it.
Less convenient but huge VFM.
In the world of analog playback, there is an interesting observation. There has been tremendous innovation in the field of
Turntable - Direct, Idler, Belt
Cartridge - MM, MC, MI
Tonearm - Gimbal, Unipivot, Linear Tracking
For all of the above designs we find some of the best reference components designed in the 50s, 60s, 70s and 80s. Most of the modern products are inspired from these extraordinary products of the past. But when it comes to phono stage, there is hardly any "reference component" from that era. They just standardized RIAA curve for sanity and left it. Manufacturers made large preamps and amps and allocated a puny 5% space for a small phono circuit even in their reference models, like a necessary evil. They didn’t bother about making it better.
The result? It came down to the modern designers post 2000 after vinyl resurgence to come up with serious phono stages for high end systems. Unfortunately they don’t have any past reference grade designs to copy or get inspired from. Effectively, just like DACs, reference phono stages is also an evolving concept, and we don’t have too many choices when we want a really good one which is high-res and natural sounding. Very few in the world have figured out a proper high end design so far. And most of the decent ones have been designed in the past couple of decades. The best of the breed are probably yet to come.
It is a tragedy that our legendary audio engineers from the golden era didn’t focus on the most sensitive and impactful component, "the phono stage"
Room Dimensions
Speaker Details
Listener Position
Let’s work on this. What’s your analog setup now ?😈
I am very happy with my phono stage. It use a 12ax7 tubes with a mosfet stage for coupling. RIAA is in bypass path. I am planning to add bypass capacitors to the tubes this month.
The turntable is thorens td150 mk2 .i bought it from
mr Jacob here in this forum … he said this particular model was made by emt in their factory in Germany . it was quite beat up by the time it reached here ..( DTDC) .. so I got a new plinth and arm board made ( just my carpenter and I ) and got some help from some veteran local mechanics to put the things back .. I don’t think the turntable has it’s stock tonearm .. the cart is nagaoka mp110H which I got just a month back ..I was quite happy when I sent a photo of the TT to the gentleman from EBI , he said it looks good so don’t do anything to it , or something to that effect .. I just play 33 rpm records and don’t fiddle around much with rpm control for the other speed ( as I have very few such records anyway ) .. inspired by some posts here I have ordered a new phono ( iFi iphono Zen 3 ) .. so let’s see how that one will work ..
