Audio Gurus Help needed -Confused on first decent quality stereo setup
Kannan_madhu
Thrissur, Keralam
i have been using a 1.5k Altec Lansing 2.1 for these years and was satisfied with its performance. But recently i heard some stereo setup and fund i am missing a lot in my music . So the search started for better sounding computer speakers but most of them although higher priced than my current set up they dint sound well. They were boomy or sharp ( and there is limited models available in my city) . Then i thought of building DIY speakers and amps but found that building speakers are not just putting some bolton woofer and some twitter in a wooden box , you have to have proper box design and you need to get TS of the drivers etc.. finding quality drivers once again become a problem, so i abandoned that my DIY ambitions and started searching this form for alternative options which led me to some combinations. But i am in total confusion which to go for.
My budget is 15K max ( will be happy if costs come less )
My source is a self assembled AMD PC with onboard sound . My first confusion is weather to go for a entry level USB dac like nuforce udac or a Asus DX or some other sound card or save the money by using on board sound .
And then these options on powered speakers or separate amp speakers
1. Creative T20 which costs 6K or Gigawaroks T3 at 13K
2. Topping amp + Bookshelf speakers
3. Audioengine a2 s
4. buy used amp and pair of used speakers
I usually listen to film songs ( south Indian / Hindi) ,some not so hard rock , bit of techno , i don't like disturb others with high volumes, need some thing which is crisp and clear in low to medium volume and got decent bass (not the window shaking one ) . Considering my requirement which of the above options should i go for ? or could you suggest some thing else which will give best bang for the buck . Audio gurus of HFV looking for your valuable suggestions
Thanks in advance
Madhu
There are some decent used amps for sale in our forum. Mate those to W10.1 or Norge speakers.
i have gone through the giant thread by psychotropic , its discussed that JBL control 1 pro and S30 are good match and they also fit into my budget which one is better matched with the T20 ?
