Audio & Video Cabling
designer
Hi to everyone!
I am having a new set up in which I will be buying a new LCD TV and a new music system.
Normaly the Music system sits below the TV, but in my case it will be some 4 meters away at right angle to the TV.
Please advice me on what types of cable I should use.
I also want to hear the sound of the TV and movies on the surround speakers.
Kindly post details of your music system.
Position of system can be explained more specifically.
Is it 4mtr height OR resting near Rt side wall?
Hi Spirovious,
Thank you for your responce.
I also need some advice on what system to buy and what speakers.
My budget for the music system is around 25K. If it cost more then i will buy in parts.
We will use the speakers for Hindustani Classical, Cable TV, DVD and Games
If you face the TV then the system will sit on your left hand side but is almost 5 feets away.
