soundsgreat
Before I start Mods if this is not the right place for this thread please feel free to move it (I couldn't a appropriate enough section for this apart from the current one
Ok here we go,Was doing my usual research on the Net and found this cool thing :licklips: !
I've been reading lot of thread related to a good soundcard, So thought to share with you guys !
Its a Audiophile Grade Stereo Soundcard Moded to the gills :yahoo: !! A but on the pricey side but hey when has anything costed cheap for Us ??
Here's the Spec of the product :
Prodigy HD2 shows the latest technology in high end audio playback for audiophile users.
Prodigy HD2 supports 192 kHz at 24-bit with a sensational dynamic range of 120dB(a) for playback - no other hardware in this price range provides this high level of output quality. Even better: the hardware is equipped with 3 OpAmps on sockets, this makes it possible to swap and exchange the OpAmps based on specific requirements.
Prodigy HD2 is a Low Profile PCI card, shipping with a metal bracket for a conventional PCI slot and with a bracket that allows the installation in Low Profile slots - this makes Prodigy HD2 perfect for media center and home theater solutions where small PC cases are used.
The included driver software is providing perfect compatibility (ASIO, GSIF, WDM) under all current Windows versions including Windows Vista 32-bit & 64-bit, offering high performance and low latency operation. DirectWIRE 3.0 support in the driver allows you to virtually patch your digital audio sources internally between different software applications running at the same time.
# PCI audio interface based on VIA VT1721 (Envy24HT-S)
# PCI card supplied with standard and low profile metal bracket
# 24 bit / 192kHz playback (analog & digital)
# 24 bit / 96kHz recording
# high quality AKM AK4396 120dB(a) S/N ratio DA converter for extremly high quality 2 channel audio playback via RCA output connectors (5Hz - 40kHz frequency response)
# triple OpAmp design for audio output with three extreme quality Burson Audio Dual OpAmps
# headphone output with 1/8" connector routed via JRC4580 dual OpAmp
# analog line input with 1/8" connector via AKM AK5353/7 102dB(a) S/N ratio AD converter (20Hz - 40kHz frequency response)
# optical S/PDIF digital output following IEC-958C standard, can be used for stereo audio playback (PCM) and multichannel streams from such sources (AC-3 or DTS data)
# EWDM driver based on ESI technology for all current Windows Versions
Its currently available only on the net via following website (they have tonnes of Audiophile Stuff but on the expensive side !!
Audiophile Soundcard
Please do post your feedback's and opinion on this !!
Regards.
Regards.
