AUDIOPHILE SUNDAY TIP # 17: EVERY OBJECT IN YOUR ROOM SHAPES THE SOUND
Fiftyfifty
Panaji, Goa
It’s not just the panels, diffusers, and bass traps - every single object in your listening space affects the way sound behaves. The rack that holds your gear, the speakers’ cabinets, the reflective glass windows, side walls, back wall with diffusers, furniture, and even something as simple as the carpet, they all interact with the sound field.
Sound waves bounce, scatter, and get absorbed depending on what’s in the room. A reflective glass window will throw back high frequencies, side walls can create comb filtering from early reflections, and a bare floor can exaggerate brightness. By contrast, a thick carpet absorbs upper bass and mids, soft furniture can tame reflections, and strategically placed diffusers at the rear wall can preserve liveliness while controlling echoes.
Small Shifts, Big Changes: Even minor adjustments like moving a rack a few inches, changing the tilt of a diffuser, or adding/removing a rug can transform the balance between clarity and muddiness. Sometimes, what seems like a “gear problem” is actually the room speaking back to you.
Before spending big money on treatments, experiment with what you already have in the room. Shift furniture, play with carpet positioning, move speakers closer or farther from reflective surfaces, and take note of the differences. Sometimes a shift of a few inches can achieve what expensive panels cannot.
What’s the one room tweak that made the biggest difference for you?
WATCH:
www.unboxaudio.in
Whatsapp: 9764227764
200% agree about the room and objects in the room playing a big part in what one hears.
Again wholeheartedly agree on positioning of speakers/rack making a change, and that's why I always keep notes on the effect of small changes I make so that it's easy to remember which setup sounded best. Even something simple like covering a wall/stand mounted tv with a soft diffuser like a blanket makes a difference in my system
I started out by raiding some pillows and stuffing them behind the speakers and progressed to building my own acoustic panels that were WAF :)
I find great joy in tweaks like this that cost little or no money
And the beauty is that all these tweaks are so easily reversible unlike investment in expensive panelling and bass traps!
