AV Receiver Suggestion...
badrisuper
chennai
I am planning to buy a new AV receiver.
My plan is to have 5 channel with 2 atmos speaker setup and add 2 subwoofers.
I gone through the online reviews and found Sony DN1080 has good review though it is 2017/18 model but supports Atmos and DTS:X.
Is it a good model or any other model I can look for?
Please share your suggestion.
Note: At present I am using Sony ST5000 sound bar.
Badri M
Is it officially available in India ? You will need to import the same from Europe for 220V otherwise can get one from the US and a Voltage converter.
If you want official warranty you can go for brands available in India like Yamaha, Denon, Marantz, Onkyo, etc depends on your preference.
I am in Europe. And here in my place its sells around 450 euro.
But I like to take time and find something sounds good and future proof. I dont want more powerful setup but moderate and decent.
Badri M
Hi Renjith
Thanks for the suggestion. Arcam specification looks good but I like to set my budget around 500 euros.
Badri M
