corElement
I dont know if this may apply to avr's across the board but...
In most manuals I find avr's saying if you have a sub you may wish to set the fronts to small even though you have large and crossover to 40hz. Some avrs have the option to allow them to remain large but still send lf to sub through preout.
I was always a bit confused about this but I didnt know what the confusion was... now I do.
When I set my fronts to small, I find it gives better clarity, clarity in terms of music because there are so many instruments playing in the med and high ranges, the lows being sent to the sub it allows the speakers to handle mid and highs slightly more clearly.
HOWEVER, when I kept using the same setting in movies, I felt it was a bit weird. Scenes where the orchestra worked up didnt seem full in movies. then it occurred to me why not change it to large and lets see if it makes any difference.
Voila! shock factor was back into orchestra scenes of movies.
So My suggestion is for people with large fronts, if you have them set to small, you might find it better for music, however in case of movies it makes a world of difference having towers set to large with full frequency dedicated to them as well as the preout giving lows to the sub.
