Axiom Speakers
blessed
Karnataka
Hello
Has anyone heard the Axiom speakers? What is the opinion about the SQ build?
Also, can anyone advise where they can be auditioned in Bangalore?
Some specs -
Specs M2
Enclosure: Vortex / Reflex
Max Amp Power: 150 Watts
Min Amp Power: 10 Watts
Freq Resp +/-3dB (Hz): 70 - 20 kHz
Freq Resp +3dB- 9dB (Hz): 60 - 20 kHz
Impedance (Ohms): 8 Ohms
SPL in Room1w/1m(dB): 94 dB
SPL Anechoic 1w/1m(dB): 90 dB
X-Over 2.7 kHz
Tweeter: Single 1"
Woofer: Single 5.25"
Sub Woofer :
Dimens. H W D (inches): 11.5" x 7.5" x 8.5"
Dimens. H W D (mm): 292 x 191 x 216
Weight (lbs) each 11.2 lbs
Weight (kg) each 5.080 kg
Please give your valuable inputs.
Thank you
heard alot of good things about axiom speakers, you may not disapponted
