Banana Plugs for Marantz SR 6008
rakheelavigne
India
Hello Marantz Owners,
I own a "SR 6008" Amp.. !!!
Are Sewell Direct SW-29751-6 Silverback Banana Plugs compatible with this?? Just wanted to chek if any one of you are using these. and do they have different sizes??
Link:
https://www.amazon.ca/Sewell-Direct...005E1CGZC/ref=cm_cr_arp_d_product_top?ie=UTF8
Gone through some of the articles on the web and some say that unless we peel of the casing surrounding the screws they dont fit.. Is this TRUE??
Any Help is appreciated.
Thanks,
Rakesh
I use these! Excellent plugs for the price. The best part is the screws hold the wire in place and ensure a good connection. Another great option are the mediabridge banana plugs. They are good quality as well. You can't go wrong with either of them!
They got quite well! Here is a pic of them connected to my speakers!
The Banana Plugs are all standard size. Mostly, all of them would work.
As suggested above, Sewell Direct and Mediabridge both provide a great Banana Plugs. Even you could have look at these:
Deadbolt Banana Plugs
Cheers!
