Basic question
hifi1975
Hyderabad India
Can you suggest how i can integrate ( connect ) Projector and TV to the AVR. And switch output from cable / DVD etc to either projector or tv as needed. Is it possible. I dont have HDMI connections so will be using RCA/coaxial cables for video / audio.
Please note i am using the AVR with output to TV as of now and alos know how to connect DVD to projector. But have to keep removing connections if i want to change output from TV to projector and viceversa.
So my basic question is ...Can i have a better setup to achieve the above . Some high level hints would do if you are pressed for time
If you are using only composite/RCA video output for both,you can use RCA/AV splitter easily available in market.
If your AVR supports both composite & component/svideo out,try to config it to get video out for either connection.
