Bass response less from Bose Soundlink Mini
Anindya
kolkata
I have a Bose sound link mini. I am finding it's bass response has decreased after 2-3 years. Is it possible? What maybe the solution? Should I take it to a service center?
Hello, I have a Bose sound link revolve plus for almost two years and I have not found that issue which you have mentioned here so far. Better take it to Bose store and have it fixed.
I have a beoplay A1 which had a similar issue but that was due to a weak battery but with my Bose soundlink air I never had problems with even when battery was lasting only an hour
Is it still in the same location or has it been moved? Are you verifying the output is lower via the same music or different music?
The position as mentioned above is critical for the soundlink and closeness to a wall reinforces bass. It could be an electronics issue as well maybe a cap or resistor causing the problem.
I tried with divergent music and close to wall position. Thanks for all your advice. I will certainly take it to a Bose service center.
