Best stereo control pre amplifiers available in India
vmscbe1974
coimbatore
Dear forum members for the benefit of all request your suggestions to best stereo control preamplifiers with phono inputs available in India, after market product performance is not satisfactory . What choices do we have in India on a budget line or hi end suitable to Indian music recordings .
Suggest Pulz RS100 Preamplifier ....proven ...im using it with Pulz RS250 and with Higher powered HA400.....Satisfied with the performance .
Norge1200 has Budget Pre and Power Combo VFM
You may also check with Telome or Sonodyne .
Hope it answers the question.
Manoj
What is your budget? These start off at 10000 rupees and go onto crores. No one can give any options without knowing your budget.
I was specific to what is available with dealers in India . Budget between rupees 25000/- to rupees one lakh . My forum question was of the best option of brands available in India .
To the max of your budget, you can consider Parasound P3 or P5 or P6 pre-amplifiers. They are master of all with a very good phono stage built in.
For a good rendering in India, you can try a compact phono pre-amp like the Fosi Audio Box X5 (MM /MC, adjustable gain) or upgrade with a Cambridge Audio Duo, comfortable and musical. At home, the Fosi surprised for its price, and the Duo is always recommended for vinyl.
I recently picked up a fosi zp3 and quite happy with it. It's super cheap but doesn't feel or sound that cheap. With a good sub out and hpf, it's quite a nice unit.
MaSh
