This is a monster dual shunt regulated power that I made. Its quite flexible in what it can do. it can use small diodes or the larger to220 ones. It has 25mm caps and a CRC filter at the input with 2*2W resistors, so a lot of voltage can be dropped here. Start with the best foot forward and give a relatively clean supply to the regulator.
All small transistors are 2sc and 2sa series, so 2sc2240, 2sc1815 etc and their 2sa pnp counterparts can be used. These are better than the bc series transistors (ok, you can shout now
). The fets are IRF510 and IRF9510.
It uses three zener diodes to set the output voltage, so a lot of flexibility is there with that. Zener voltage is filtered with both a film cap and a electrolytic cap and then its buffered before using it to set the voltage. This build sets the voltage to about 16.5v and runs at about 300ma. Of course the heatsinks are not enough for that without any load.
It has 4 output points per dc rail, so more than one project can be powered from this, like a preamp, phono pre and headphone amp etc. Separate connection for earthing is also provided. The pcb is quite large at 4"x5".
I have also a BluesPowerMini coming out soon which is a much smaller board with less features and more suitable for a single project.
Some Pictures:
Some Pictures:
