Booked Denon 3311
Amit21
Ahmedabad
Hi Guys,
After lot of extensive research, today i have booked Denon3311....Should get it by Wednesday / Thursday....:yahoo:
Hi Venkat - Thanks for your valuable inputs....It actually helped me in making the decision.
Amit
hi,
If you are comfortable will your share with us the price you paid for 3311.
cheers
Which speakers will you be using with the Denon 3311?
Any idea if the 2311 has 7.1 Pre-outs?
Congrats & Enjoy:)
Price - 76k,
Yes 2311 do have 7.2 preout
Presently I have wharfedale 8.4 tower,8 centre and 8 dfs.....will be using same only.....I do have the plan to upgrade them sooner.
I should get the unit delivered by wed ....will surely post my first impressions and review too.....
Price - 76k,
One of the dealers in Mumbai told me the 2311 has no Pre-outs:confused:
Waiting for your review:)
Pls find the below specs for 2311
Main Specifications
Power amplifier section Preamplifier section
Rated output *THD figures are power amp stage values. Input sensitivity/impedance 200 mV / 47 k?/kohms
Front L/R 105 W + 105 W Frequency response 10 Hz ~ 100 kHz +1, 3 dB (DIRECT mode)
(8 ohms, 20 Hz - 20 kHz, THD 0.08 %) S/N Ratio 100 dB (IHF-A weighted, DIRECT mode)
135 W + 135 W
(6 ohms, 1 kHz, THD 0.7%) FM section
Centre 105 W Tuning frequency range 87.5 - 108 MHz
(8 ohms, 20 Hz - 20 kHz, THD 0.08 %) Usable sensitivity 1.2 ?V, (12.8 dBf)
135 W
(6 ohms, 1 kHz, THD 0.7%) AM section
Surround L/R 105 W + 105 W Tuning frequency range 522 - 1611 kHz
(8 ohms, 20 Hz - 20 kHz, THD 0.08 %) Usable sensitivity 18 ?V
135 W + 135 W
(6 ohms, 1 kHz, THD 0.7%) General
Surround Back L/R 105 W + 105 W Power supply AC 230 V, 50 Hz
(8 ohms, 20 Hz - 20 kHz, THD 0.08 %) Power consumption 600 W (Standby 0.1 W)
135 W + 135 W Dimensions (W x H x D) 434 x 171 x 381 mm
(6 ohms, 1 kHz, THD 0.7%) Weight 11.0 kg
Ports
In HDMI x 6
Component x 2
S-Video x 2
Composite (Video) x 4
Analog Audio (Tuner included) x 8
Digital Optical x 2
Digital Coaxial x 2
Out HDMI Monitor x 1
Component Monitor x 1
Composite Monitor x 1
Composite (DVR) x 1
Audio Preout (7ch) x 1
Audio Preout (SW) x 2
Audio Preout (Zone2 L/R) x 1
Audio REC out x 1
Phones x 1
Digital Optical x 1
Other USB port x 1
Microphone Port x 1
Dock Control Port x 1
FM Tuner Antenna x 1
AM Tuner Antenna x 1
Remote Control In/Out In 1 / Out 1
RS-232C x 1
DC12V 150mA MAX. trigger out x 1
Hi Samuel,
Yes i am getting Free BDP with this (DBP 2010) .. ....You are correct the published price is 90K....after good nego i got the price of 76K
Amit - Is it 2311 or 3311?. There are references to both the numbers in this thread.
Must be 3311 looking at the price but can you confirm for the benefit of others.
Thank you.
Hi Siva,
I have booked 3311....but fran_elite was interested to know whether 2311 has got preouts or not? ...and hence i have posted specs for 2311.....
I hope, i am able to clear out the confusion now ;);););)
Hi Guys....just fyi....US model of 2311 deosnt have preouts.....but if you buy it from India than you will get the preouts..... (Singapore model also have the preouts)....
Hope this will help if any-buddy plan to buys it from US
Yes, it is an Excellent offer......but you need to use good negotiation skills to get that price.....just telling you based on my experience of 3311....
