Bookshelf Speakers for a Stereo - CA Azur 650 A
jagdish_p
Hyderabad
Hi everyone,
I am planning shift my Integrated Amp- Cambridge Audio 650A into a smaller study room. I plan to buy Bookshelves for connecting to the amplifier which wil be mostly used for listening to Music - All genres. Source will be High Bit files stored on HDD - played through a Media player connected to Amp through CA DacMagic.
I am confused about which speakers to buy? I did listen to KEF Q 300 and liked them - though I felt that the Bass was a bit subdued. I have to stretch my budget to buy these speakers. Do the KEF Q300 speakers match well with CA Azur 650 A amp?
Also do the forum members have any other suggestions for the speakers.- under 30 K.
How will the PSB Image b6 speakers suit the above set up? Unable to find them in Hyd for audiotionng.
Mordaunt Short s Aviano 2 and Mezzo 2.. they are a very nice,tried-tested combo.. Mezz2 will be a bit costly (30k +) and Aviano 2 comes in the range of 21-24k a pair
Thanks for the suggestions. I have not been able to locate them in Hyd ,will try and audition the speakers next when I go to Mumbai
-The reviews for Epos Epic2 are great - Any one knows the exact price? Also their site recommends that these speakers should be mounted on stands which may not work out for me due to small room size (10X8 feet)
- Any insights - PSB Image B6 vs MS Aviano 2 for pairing with 650 A ?
MS Aviano and Mezzo are available at SBT corporation, Rajbhavan Road, somajiguda.
Price is around 32 to 35k. Stands are must.
Has any one heard PSB Image B6 Bookshelf paired with Azur 650 A.
How does it sound. I am interested to try these speakers also as they are advertised for use in restricted space.
Auditioned Aviano 1 (SBT Hyd did not have Aviano 2) and liked them a lot.
Would like to Listen to PSB Imageb6 and Epos Epic 2 also before taking a final call. Can any one in the forum let me know where they are available in Hyderabad or Mumbai.
Tending towards Aviano 2 only as Epic 2 are costly.
I paired CA AM-5 with image-6 & sound was good.Synergy was perfect.Frequency response was smooth.650 can handle it better I think.Try having demo.
