Bose companion 3 series 2 100-240v AC 50/60hz
mielski
Philippines
Hi, I bought a Bose companion 3 series 2 in the US, and im from the Philippines that uses 240v in outlets.
On the back panel of the subwoofer, it is printed there that it can take 100-240v 50/60hz. I just want to make sure that it can reallt handle 240v.
Does anyone has the same thing written on the back of the sub? Thank you!
If it is written 100-240v 50/60hz, you can definitely use it in any country where the voltage is within this range.
You can use the Subwoofer with your mains voltage.
