I've just set my KEF Concord speakers up on a tiled ceramic floor and the sound seems to be more brittle than when I had a wooden floor or carpets. Do you think they're actually producing a more "accurate" sound, or should I put some absorbent material under the speaker legs to dampen / soften the sound? If so, what material would you recommend? Or perhaps I should simply adjust the bass/treble controls?
