Broken unit, how to fix?
Murlidher
Chennai
I accidentally dropped one piece of ceiling speakers because of which a small piece came off. Please advise if this is easy to fix ?
Two-part epoxy can be used to glue. I wouldn't use superglue as it has a tendency to flow to undesired parts. It also has a very quick setting time of just few seconds. Epoxy has 5 minute setting time and gives much more time to correctly align the parts to be glued. Allow it to cure under pressure for best results.
