budget floorstanders to go with Denon 1610
simple
I plan to buy Denon 1610, and am looking to buy 2 floorstanders ( under 20K for a pair) to go with them. After a couple of years I will add surround and center. No plans to add a seperate subwoofer ( want to keep the system neighbour friendly as I live in an apartment).
My usage is mostly movies, but still am looking for clear and crisp sound and not necessarily the "thump".
Any recommendations for floorstanders within 20K? And places to buy them in bangalore?
Choice can be MS,Mission m33i for said budget.
Simple,
You can opt for Mission m33i or m34i in your budget.
Ms 902 or 904, I am not sure which one, also falls in budget.
If you dont mind bookshelves, do check out Usher se520. You can audition it at ARN, Bangalore.
Decibel deals with Mission in Bangalore.If you can stretch to 27k, I would say the Q accoustics 1030i would be worth it.
