Tony3d
Now that I've solved that slight buzz I was getting from my Dual 701 turntable, I want to know if I use a fairly high quality cable, that is about ten feet longer will it introduce buzz again? Before I was using two cables joined together by two radio shake couplers. When I removed the couplers, and plugged the table directly into the preamp with the 5 foot cable the buzz disappeared. I'm assuming it was the couplers, and not the length of the two cables.
