Cambridge Audio DacMagic XS USB DAC
Hi Friends,
Do you know if Cambridge Audio DacMagic XS USB DAC is available in India ? Where can I buy it ?
There is a Cambridge Audio DacMagic for sale you can check that out
I guess you must know, if you have been following that product, that there is a new, improved, cheaper Dragonfly now.
Such a small thing would probably come in the post with no problems at all: buy from abroad.
Yeah Thad E Ginathom, I have decided to go for Dragonfly. But which version ? The old one is now very cheap. Should I go for it ? This will be my first DAC.
Hi Rupam
Have you bought your dac or still searching. I am also looking for a dac and therefore looking all related thread to find if anyone has purchased and satisfied.
Rupam, If you intend to use it only with your AVR then better get ODAC since you do not need the built in headphone amp.
