Can 2 Amplifiers be connected to 1 Pair of Speakers?
I am having the same problem, but continue to live with it for the time being. I have a yamaha AVR which is connected to the 5.1 speaker system. This arrangement is for AV inputs from STB,DVDP, PC etc( for music, I use only the Front speakers). I also have a Harman Kardon Int AMP which is connected to the TT. Two separate set of cable run from the AMP and AVR, which I connect/disconnect to the two Fronts with great difficulty, as the speakers are kept in such a way that it is not possible to reach behind them. Every time I have to drag it forward & turn it around to connect the cables. Discouraged by this exercise involved, my vinyl listening has become limited.BTW, the item shown on e-bay as suggested above, is for one input & 2 outputs not 2 inputs & 1 output. Will it work in this case?
