V vickey New Member Joined May 4, 2011 Messages 7 Points 0 Location Pune Mar 1, 2012 #1 I'm in power Amp search, already own tube preAmp Just wonder if I can pair Cadence VA1 (Tube Integrated) as a power Amp? If Yes then How thanks in advance, Vickey
jls001 Well-Known Member Joined Feb 9, 2010 Messages 6,182 Points 113 Location Mumbai Mar 1, 2012 #2 VA 1 is an integrated amp. I very much doubt the designer would have put a facility to split the pre and power sections (usually using U link connectors externally to connect pre to power section).
Absolute Phase Active Member Joined Jul 25, 2006 Messages 458 Points 43 Location Bangalore Mar 2, 2012 #3 No you cannot use the VA-1 as a power amp, its a dedicated integrated amp. The best option is to get a decent power amp.
