Center Channel Cutting Out
sandeepmohan
Wellington
Hi Folks,
I've got an old Denon AVR 3312 as my HT base. Running 5.1. Though its old gear, it has worked flawlessly.
We were watching Untamed on Netflix (Highly recommended) when out of the blue the dialog channel cut out. I could not hear any dialog. Had to switch to Stereo to continue watching. In the middle of an Episode I flipped back to Surround and the center channel was back. Only to cut out in a few minutes. This was accompanied by some relays clicking inside the AVR. I shut down the receiver, TV, turned off power completely, swapped HDMI cables. The issue fixes itself and then moments later, I loose the center channel again. The AVR runs barely warm (even at 60% gain) so not a case of temperature cut out. Checked speaker wires and I can't find any shorting. Interestingly when I run a speaker test tone via the AVR interface, the center channel does output a signal. Its only when viewing content, there is no audio or dialog.
Any tips on how to diagnose the issue.
Redo the center channel wiring, check if there are any stray strands that have come lose. You could also try to reset the receiver, do not add any additional gain at source or at speaker. Run auto setup and switch all speakers to Small with crossover suitable for what your sub can handle.
If still the issue persists, get the receiver checked by a trusted technician.
MaSh
Hi Folks,
You can try connecting the center speaker to one of the fronts just to be sure if the center speaker works although the test tone confirmed it to rule out issues with the speaker.
Pls try a difference source like a bdp or a cd in different surround modes to see if the issue persists. Last option is to do a factory reset and redo Audyssey.
The speaker wiring was already checked. There are no stray strands of wiring anywhere
Audyssey or the receiver unit has not been reset yet, cause I don't want to go through the ordeal of recalibrating the whole thing all over again.
Interestingly, I did a Google search for the issue and found a few who reported the exact same issue. The solution is a joke but does seem to work. Tilt the front or the back end of the receiver a little bit, maybe half an inch off the surface and drop it. I did this and got back the center channel immediately.
The issue is due to sticky or failing speaker relay within. They can be replaced which will resolve the issue. I'll hold till such time the issue becomes a pain.
