center channel/surround speakers
sashidhar
bangalore
Hi Group,
I presently have the 2.1 system with Yamaha-3067 receiver and mission vx-3 speakers. I would like to go for center channel/surround speakers and budget is 20k.
Would it be better to purchase those speakers as well from same company Mission OR can i go for any other made? using speakers with mixture of different companies has any impact on quality? Receiver seems to be with Imepadance of 6 ohm, can i use any speakers with impedance >=6 ohms?
Please suggest, speakers from your experience in this budget.
Thanks,
Thank you for the suggestions. Can i add centre channel alone speaker right now to make it 3.1 and can add surround speakers later when i have budget?Will it work or do i need to add all three together?
I will suggest you go for mission speakers only. You will not face timber matching problem and will have smooth and coherent surround sound. Preferably same series from mission.
Sent from my Le X507 using Tapatalk
One of the FM has post a Classified about Jamo speakers, just check if you like and are within your budget.
