Center Speaker Upgrade?
dnshrajn
India
Dear FMs,
I need all your suggestions for a possible upgrade.
I currently have a Denon X2000 AVR, with Dali Zensor 3 as Front LR and Dali Zensor Vokal as centre. I use QAcoustics 3010i as surrounds and SVS PB1000 subwoofer.
One of my friend has a Dali Ikon Vokal 2 mk2 centre for sale. I am considering to upgrade. I want all your suggestions and advices regarding this. How this will work with my current AVR
I have also have plans to upgrade my avr in near future. Since my denon is more than 10 years old now.
Thank You
Dear FMs,
Thank You
Suggest you compare the specs of both center speakers and refer to possible online videos available on Youtube posted by end users if you are not able to audition the same in person and take a call. Use the same AV content when listening to these center speakers so that you can personally draw an inference and make a proper decision.
auditioning in similar conditions is bit difficult. I was more worried about the synergy / timber matching between the Zensor fronts and Ikon center although, they belong to same brand. Also, im worried about if my x2000 would drive it easily.
